Ok-- im stating to drill shop----
I think I want the tinyist palm drill in 1/4 inch size---- CP-7300 looks like it would work--- its plain bearings- 2600 RPM- its pretty small-
I THINK I want a variable speed with a good controlable trigger...
Since it will be used mostly for # 2,#3 and #4 rivet holes--- the bits will be relatively small--- so I am thinking that a bit higher RPM would be helpfull.
I see lots of them that run 2600 - some at 3600 and a few at 4000 RPM.
What would be an ideal speed range for these small drill bit sizes ? Im assuming the starting point as you squeeze the trigger would increase proportionaly as
the top speed rating got bigger. Im thinking the "turn-on" speed might be important when starting a pilot hole ( that is not having it TOO fast ..... )
I have only used the cheap, ugly non-variable speed ones.... with an all or nothing trigger..... (not used friendly ! )
The cheapest sioux appears to be about 250$ at brown tool. CP-7300 about 140$ A used sioux would be fine if I could find one localy to inspect its
condition. I think i like the smallest "palm" style for rivet drilling.
Opinions ?
Tim
Opinions ?
Tim
