I now have a 30 Ton jack on my rubber pad press. That extra push got my lightening hole close enough to 30 degrees that Im
happy now on that.
When i am doing the fluting and straightening operation--- I finish the outer flanged lip from about 75 degrees to 90 degrees using the
RV overbending tool. then I alternate between that tool and fluting until the edge of the flange perfectly touches the table all way round
and the flange is 90 degrees with no bumps sticking up high. When I get to that stage-- i still have some front-to-back potato chip
bend. I flip it over on its back onto a rubber pad and hit the flat areas with my small dead blow to bend the bowed area back the other way.
The rubber pad underneath is intended to give the work a little room to move..... and to facilitate the un-bending.
After I do this several times--- and then continue to adjust fluting and so forth---- I end up with the end-to-end bend better but not
completely gone. When I am all done- the cut edge of the flange touches the table all way round-- flange is 90 degrees with no
bumps....... and when I flip it over down flat---- if I put my finger in the flat area between the two lightening holes- I still have a gap
of between 3/32 and 1/8 between the metal and the table. I have not added any of the stiffener angles yet (but I expect they will have no
effect because that bend is 90 degrees to them)
My question is ---- when those ribs are mounted into the wing---- will that slight curve have any effect as long as the outer flange
is square and flat (in a single plane in space) ? Do I need to work harder and get rid of ALL that bowing ? Or-- is a little OK if
the flange is 90 degrees and flat on the table ?
I have done the first 15 nose ribs for one side. Hope I havnt wasted a bunch of expensive material. !
( I have noticed when I have tried more agressively to un-bend that bow - it can induce a wrinkle in the edge of the lightening hole.
I have to go back and try to un-do it with the bob-tool. even being as careful as I can be- after working it out- it is never quite as
smooth and even as before------- hence I want to know If what I have done so far is good enough.)
Thanks ahead of time -
Tim
happy now on that.
Tim
