Hi all. Just a quick question to those in the know. I'm in the early stages of overhauling my O540. It has a A1D5 designation which means it is rated at 250 hp at 2575 rpm. I don't have a prop yet so can still source an appropriate prop for the designation I have.
So here is my question: should I stay with the current designation or should I convert the engine to A4D5 to accomodate the compact hub Hartzell props? And if I then go there, should I then go for the E4A5 that delivers 260hp at 2700rpm?
Any views on this as I suppose prop availability will be be major deciding factor with some consideration for the additional 10hp.
Thanks
Thanks
