Rear spar cap strips modification
  • Rear spar cap strips modification
    Dear all. Is there an approved alternative to construct the 4 place BH rear spars without making use of the 166 inch cap strips?
    I find it very difficult to obtain these strips localy and to import it from the USA is going to cost me in excess of $160 each! (8 needed)
    Help please
    The only person I know who approves alternatives is Bob Barrows. I bet he will have a very good alternative for you. For example, I think if one were to replace one cap strips with two that are 1/2 the thickness, it will yield a higher strength. That material may be easier to source for you.
      I discussed this plan with Bob Barrows and he gave me the go ahead on this splice. I used 2024T3 0.125 to make the capstrips. Bop said mine will be stronger than the 6061
        Thanks guys. Thanks Gerhard. Will study you proposal. Looks good.
          I suggest doubler cap strips where the splice is. Front & back. With 5 or 6 rivets on either side of the splice. Mark
