I know that this is common knowledge to a lot of you guys, but in case someone is struggling like me, here is how I solved the problem. I was trying to install the 491 hose fittings on the hose. I visited Eric Newton's site and noted his comments and fotos. After about 3 or 4 hours of trying, I gave up. I decided to visit Newton's site again, thinking I missed something. Now Mr. Newton is a young, stout fella. I am 78 years old and weigh about 135 Lbs. Uh oh. Next day, a friend came by to see my progress. Here is how he solved the issue for me. 1) After cutting the hose with your whiz wheel, use a razor blade (Xacto knife) to bevel the inside of the hose just a little. This will make it easier to start Fitting Insert into the hose. 2)Put the Fitting Base on the hose like Newton shows you - Fitting Base goes in the vise, and screw the hose on CCW until it bottoms and then back off a little. 3)Put the Fitting Base back into the vise vertically instead of horizontally. 4)Take you 9/16ths deep well socket, and your ratchet (if you don't have a big enough drill) with a small piece of wood so you can press down hard and slip it onto the Mandrell/ Insert and Nut. 5)Using the wood to press the on the ratchet, begin to screw the Mandrel/Insert-Cap into the hose. When it catches (you can tell right away), screw it in (you don't have to lean on the wood anymore) until there is a little less than 1/16th clearance between the Fitting Base and the Cap. Ta-Da!
AeroQuip 303 Hose Ends
I STRONGLY recommend taking time to investigate each hose-end you assemble, for partial blockages. Minimum requirement is to run a rod through the hose and ensure it's totally clear.
I ended up with some rubber grommets being formed by the assembly process. These came free and collected in the end-fitting of the smallest fuel line. Compressed air and flushing didn't identify/remove the problem. These restricted fuel flow enough to starve the engine at 1400 RPM. Had this problem presented in-flight instead of during testing, it could have been serious.
