Just wanted to give heads up to scratch builders on issue that I came across on the trim tab hinges during covering and installation.
Take this point with the following disclaimers:
Problem is that thin a wall of tubing, I didn't have enough clearance for the thickness of the fabric. I had to eliminate the fabric in the area of the hinge tubes to get a good fit and smooth motion. Even though I covered with heavy fabric, I'm sure I would have the same issue with medium fabric. I would consider going with a thicker wall tubing like 5/16" x .058 next time.
One other little point and this one does have to do with decision to use heavy fabric. When I shrunk the fabric, the bow of the elevator pulled in a bit and caused a bit of clearance issue at the rear edge. So much so, that I had to put a spacer where the trim tab should be while fabric shrinking.
Just relaying my experience based on the decisions I made. Expect others had better results. Hope helpful.
- super amateur builder
- decisions made years ago, results today
- not sure what current plans specify
- I covered tail structure with heavy fabric for off field abuse
