I had a rotisserie design that I was using but it was not really easy to lock the fuselage in any given position. Here is my redesign finished today. I used engine stands from Harbor Freight that were on sale at $39 each as supports. The rotating mechanism uses a PTO drive shaft from some AG equipment. The rotation position is locked by a spring loaded pin engaging an $8 40 tooth gear sprocket. it works very well and quickly gives a secure position lock.
