Frank
Well-known member
It was suggested to me that deburring drilled holes should not be done with a deburring wheel (2024 T3). This is important consideration because I still have a LOT of deburring to do on the wings and elsewhere. I plan to etch and paint parts before assembly, if that mitigates any problems.
But here are the comments: "The alclad has been removed with the deburring wheel. Putting a fastener(dissimilar metals) through the hole will cause corrosion in the area over time.” And even though I will use solid aluminum rivets on aluminum parts, "It is not the aluminium itself that is the problem but the alloys used.”
Bottom line, can I continue to deburr with the Scotchbrite wheel and pads, or should I strictly use deburring tools?
