Originally posted by robcaldwell
View Post
If you like assembly, something that I'll often do is design interlocking parts and cut the slots just the right tolerance to slide in with a tap and hold. Sometimes hit it with a pinner and glue, screws if I want to take it apart later. Those joints that nest are very strong even with minimal screws to suck them up tight.
HDPE plastic cuts very nicely and is extremely useful for that space between wood and metal. I cut these RC skis out of 1" HDPE/aluminum. They have an integrated slot that sets the angle limits and spring to keep them tip up in flight without using cables.
