If you get a stubborn hinge pin consider the following
I managed to pass a 72 inch stainless pin thru a stainless hinge with no assistance except a drill, and some lubricant
1. Apply oil to length of pin (except the end you are working with)
2. If you have a second short length of pin place it in the opposite side for alignment
3. Apply a tiny drop of lube to each hinge loop ( much like you would a bicycle chain)
4. Take the tip you are passing to your sander and make it pointy but not sharp.
5. Hook the other end up to the chuck of your drill
6. Drive the wire in short bursts back while loosely aligning the loops w your other hand.
7. Depending on the geometry of what u are working on the drill may get in the way as u approach the last few inches. Remove the drill tap the rest in w block of hard wood and mallet. Alternatively start w a longer than needed pin and cut off the excess pin needed to bend the drill away from the surface of what u are working on.
Perhaps this is common knowledge and I just figured it out the hard way.
