I’ve been kanoodling a concept that would be retrofittable - a linear actuator that can be mounted either fore or aft of the pedal assembly and on each cable attach point - you could either wire it with an on/off as well as a push pull button (push left, pull right side - or vice versa) OR keep the control simple and just have a on off. That way you press right rudder, switch power on for the holding torque, power off removes holding torque. The second sounds easier to not forget if when brains get saturated - I’ll come up with a ready to install plan, but won’t do so until after flight testing and I feel that for myself rudder trim would be desired.
lots of theory and a few unknowns,
-what would the off resistance be to the pedals?
-w/ a simple on off, maybe just set holding power to a single actuator for the rudder pedal that is desired(less to overpower?)
-what is the overpower scenario, can I forget to turn off the holding torque but still over power holding torque without damage in order to control the aircraft
-what is the least amount of holding torque needed? What kind of upper limit? (No idea b/c I’m not flying yet, this drives the concept to be retrofit-able)
I’m hesitant to participate in discussions, b/c I’m not flying….yet. That doesn’t invalidate an idea or opinion but should be made crystal clear on every post (your user status can change over time) for those reading to be aware and appropriately cautious. The culture should allow discussion, so long as your disclaimer is visible so we don’t have a blind leading the blind situation.
