Request for feed back:
I'm curious. I want to bevel and shorten the Door latches steel rod so it can be slammed shut. I am scared I'll mess it up. But if the experienced can guide me I will do it.
As designed, the latch will just bang on the door frame, bounce back open, and someday will dent and damage the frame or the latch. Have others modified theirs? I envision a 45 degree angle (Would 60 degree angle be better?) with a striker plate riveted to receive the latches extended beveled steel rod. It seems I saw one at Oshkosh and wish I had more details on it.
I also show an aftermarket door latch from Spruce that I did not install due to the need and subsequent fear of welding, warping, and screwing up the door. Its bevel looks like 45 degrees. What you see in photo 1 is Bob's/the kit design.
