There are small angles which hold the window material between the angles and outer trim pieces on the window frame. Technique shown in the build manual uses epoxy of some sort to secure them. Any suggestions on the particular epoxy to use and or other techniques? (Screws come to mind, possibly rivets, though not sure there is enough room to set them) Open to all suggestions or thoughts. Thank so much.
Dave from Maine
Dave from Maine
