Back in the Game
Any time spent with a hole saw or a Uni-bit, is quality time! It pays off in satisfaction years down the road, every time you look at a part you spent a few more minutes on lightening, it has for me anyway. I have holes in my S-7S where no one else has, my thinking is the kit company stamps the part out, and they are done. That doesn't mean you can't put holes in it! The fun part is being smart about it of course. Also, when your plane comes out heavier than you wanted, (a given...) it helps a lot to know you did all you can to keep it light as possible.
Well, here's a point where I add some weight, been debating this with myself for a while. Gonna install a small cargo "hatch" for two reasons. 1. Make servicing ELT and controls that are behind the cargo area easier 2. Loading things behind the rear seat will be easier also.
I call it a hatch because not putting hinges, using quarter turn fasteners. Seems the lightest and clean aerodynamically. But still quick to open
The Hatch opening mostly done. Need to deburr and rivet. .025 was used for the outer ring and .020 to form the angle pieces. Two tabs were welded for lower attach point, aft attach is an existing tab for rear baggage closure and upper is simply drilled to stringer.
I'll weigh it before installing permanent just so I know what it cost me, other than a day of work an a few scraps of metal.
My initial thought is to use Dzus fasteners for the cover. Any other ideas are welcome.
One suggestion.
When I shrank my fabric, it wanted to "roll" the bottom of the window frame out. I needed to reinforce it so(since the fabric was on I wasn't going to weld) used an Adel clamp on the diagonal tube that is roughly at the center of the window frame tied to a small aluminum bracket connected into the stringer that runs under the window frame.
I would suggest welding another "stringer standoff" to the diagonal tube at roughly the center of the window frame to better support the stringer against the tension of the fabric.
Thanks for the heads up, I've already riveted the frames on. So will look at it and come up with some sort of attachments without welding.
I recently installed my tail inspection frames and covers. Your cargo opening looks similar in design. Your material is exactly what I used for the frame and cover. Follow Stewarts Systems advice and attach your frame to your fabric from the inside after the first shrink to 250. After the glue cured an X is cut and fabric pushed through the frame, wrapped around and glued from the inside. The frame gets encapsulated.
If you choose to install quarter turn fastener receptacle after you cover & wrap, you eliminate obstructions from allowing fabric to adhere solid without those obstructions. After this photo was taken I riveted (squeezed) 4 tinnerman nut plates in each corner of the lower frame. It worked out nicely.
I also applied a zinc chromate coating to these frames. The AL gets roughed for a Stewarts Glue mechanical bond. I wonder if the AL might corrode over time and loose glue adhesion. So I roughen it, clean it, Chromate it, then glue it.
Click image for larger version  Name:	Screen Shot 2022-02-21 at 1.45.04 PM.png Views:	1 Size:	569.3 KB ID:	72955
One of the mods I did on both of my S-7 builds, was a aft baggage door, no regrets. It allows me to get into the area behind the baggage area, where I can keep light gear like a mattress pad, pillow, anything light but bulky. I also put a "ski hatch" in the plywood bulkhead at the rear of my baggage compartment, good for carrying 10' long PVC conduit, or a 78" Prince prop, both which I've done. Good advice on the fabric tension pulling things out of whack, as usual any mods lead to extra work!
Ok, got it done except for attachment and camloc fasteners, After seeing how much Camlocs are I elected to hinge it. Now we'll call it a door
The dorsal fin area on any plane has always given me cold sweats, real visible too! But they have always come out OK just pretty challenging compared to most other areas.
Fuselage is covered, finally! Ekobond to seal the weave has been applied, shot the 2 cross coats of ekofill. Now to listen to some music while I sand for the next week.
More ecofill, more sanding. Hopefully some color in a week. Oh yeah, ironing a few edges down too.
Got the bottom painted white. Gray stripe shot today. Red will be shot in a couple days
For those of us flying completed aircraft...., watching your progress is a reminder on how much work ANY airplane is to build! Note to self: "Be careful, don't wreck it, you've forgotten how much work it was to build!" Coming up on 3000 hours flight time on my 2007 S-7S build.
Red on, then reshot the gray because the edges didn't come out good. Second go worked thankfully
  • Like
Reactions: LWR
Beautiful. I think you've posted on YouTube. If so, I've spent the better part of a year looking for your updates like I'm somehow responsible for knowing where you are on your project haha. Love it
Made some time to install the Leading edge protection on the prop , balanced and good sealing clear coat. I decided to start with 76" diameter and 46" pitch. This will yeild approx 123mph at 2600rpm tas. Now I need to hang the engine (-:
Boot Cowl progress. Hopefully a couple more days and I'll be hanging the engine.
A few more pieces of the puzzle done. Got the top boot cowl sorted and drilled, and some of the bottom. Few more hours of fabrication then I'll be installing nut plates and rivets. I made the inner piece removable for future maintenance
Just a few more nut plates and boot cowl is done all but paint.
Sometimes it seems as if removing the plastic covering from the sheet aluminum takes longer than making the part. Lol
And finally,, if you haven't bought the nut plate jigs yet, do it now. I can't believe I waited this long to get these.
Wings mounted one more time before paint. This gives me the opportunity to finish all details like skylight, wing fuselage intersection fairings, windscreen etc. Hopefully the next couple months will produce an airworthy craft.
Getting the exhaust sorted out.
PropMan
The timing of post #95 is impeccable! I installed my exhaust yesterday and for the life of me could not figure out the way to attach the stabilization thingy-ma-bobs (with the blue hose), your photo gives me hope.
Thanks
While waiting on a few things for the engine install I decided to finish up the fabric work. Covered the seats with heavy fabric, now working on tail surfaces. Looks like a couple weeks to get thru paint, we'll see
The couch in the background says it all, that's the way a shop should look! A buddy lives in his hangar in a nearby town, totally outlaw of course, and when I see his latest project (a very prolific builder) it always cracks me up to see: a drill press, next to a metal brake, next to a micro wave, next to a hydraulic press, next to a waffle iron, you get the idea. You've inspired me to move an unused sofa chair out of the basement and put it in the shop, tomorrow. if nothing else the shop cats will appreciate it. You are getting there, looking good.
Glad I can add inspiration. Lol
Half of my hangar is conditioned all the time, I find when the climate is comfortable much more work is accomplished. Unless I need a nap
Got the bottom side of h stabs covered, lots of distractions with this arctic blast that came thru, plus Christmas.
Spent an hour refreshing my memory on stitches, then 4 hours stitching. All but right side HS done and ready for tapes
I SO not wanted to rib stitch, but in the end it was easy and adds a cool retro look rather than the rivet look.
Finish tapes all done on HS, elevators and rudder. Sealed the fabric with ecobond. Time to spray ecofill then paint
Got the tail parts primed a week or so ago then it got too cold to paint. Sorted out the mounting for my Trig equipment. Constructed so removal of the front two bolts allows it to swing down for maintenance
Sorting out wires
Just when I get rolling on one part I realize something else needs to be done to complete the first task. Lol
Wiring stopped to get baffles done so I can terminate engine monitor wires properly, then I realize the cowl needs to be done for the baffles. It's a vicious cycle. But will be done SOON!
That cowling has taken me about 2-3 months when you figure in all the little details involved. The low pressure lip was 25+ hours. I am glad I am “nearly” done with the cowl, just a note, it takes a lot of planning.
Working on Windshield
  • Like
Reactions: Nev
I Hate fiberglass work. Took all day to make the lower Windshield trim. But it's done except for final trim, filler and paint.
Almost forgot, Edging trim came in, finished the tail fairigs yesterday also.
More windscreen trim. Vertical side pieces. I bent them so a lip is formed for the window frame rest in the lip. Will add edge trim or foam as needed
Side window time! I had the left window partially fitted. Finished the front vertical trim forming on the left then started on the right side. Cut the Plexiglass, trimmed all the small pieces that back up the glass then , cut outside trim. Measured 30 times? then drilled the assembly in the workbench.
checked fit, trimmed to fit , then bent front vertical piece to fit
I chose to use rivets for window trim and Plexiglass attachments. Trim is an assortment of ccc32 and and 426ad3 where possible. The plexi is sandwiched between aluminum trim and fastened with aacq44, an all aluminum pulled rivet. The interior is painted a smoke gray, exterior will be painted to match fuselage later
Spent half a day turning perfectly good aluminum sheet into scrap. Happens sometimes
I've been working on wing fairings for what seems like a year, reality, couple weeks. Almost done tho, decided to make the front to windscreen out of s-glass. For a better fit.
Got a pair of leading edge fairings after a couple days effort. Amazing how much work it takes to make form fitting parts
20231120_162115.jpg Lots of challenges with this cowl. Currently working on the lower portion. The lower side support angle is twisted an needs a curve in it for a nice transition to the nose. One piece at a time is how to eat an elephant. Lol
More lower cowl work. Got he support angles shaped, positioned the lower skin and started to drill
I learned recently the carb heat inlet to the airbox must be relocated to the rear of the box. Today I hacksaw the part off, welded onto the back and riveted on a cover of the old position
Lower cowl airbox cover mock up and fab
Lower cowl parts are fabricated and drilled in place. Time to debur, dimple and rivet together
Cowl doors fitting. Time to drill fasteners and buck rivets. Almost to final trimming too.
Prop Man;
I'm curious about the curved radius on your cowl doors. The fabrication of them is in my near future. Did you form that radius into the door, and if so did you use a slip roller or maybe by hand over a cylinder?
Brooks, it's all by hand. I slowly bend where needed. Step back and look at it, then bend more. Slow and tedious work. The most difficult part was the angle that supports lower cowl. It bends and twist. That one has to be hammered ever so slightly.
A couple of pieces of PVC pipe to bend over (I think i used 4 and 6 inch diameter) doesn't hurt but I did it mostly by hand as well. Go slow and "creep up on it".
I decided to paint the interior fabric with a light coat of gray, two rolls of masking tape later. It's ready for paint
The skylight to windscreen channel is not weather tight, has welds every couple inches. So I mixed up some proseal, neatly applied and painted the piece.
light weight simple
On my plexi windshield/Lexan skylight junction, I used a product called Lexal (maybe Lexel), and 16 years later it's still perfect. Available in crystal clear (and it is) or white, caulking gun tube or smaller sqeeze tubes, specifically designed for bonding various types of plastic to each other. I used it after a tip from a fellow builder, and it's been my goto adhesive since then. It stays semi flexible, and any Ace Hardware store stocks it along with their other caulk, but don't let that dissuade you, (I'd order it from Spruce if I had to) it's a great product for many things!
I second that! Lexel is amazing stuff. I hadn't thought about using it on the BH since I am not to that stage yet but I have used it to seal leaking automotive windshields, body seams, headlights, and a multitude of other applications.
I followed your advice. I adjusted the pipe diameter by wrapping it to the diameter to provide my desired radius. This is method worked better than rolling it. Faster, easier, more sure of end result.
Got the gear covered, painted and installed. Haven't made much progress other than that. Been building a 2500ft strip to replace the 1300ft one I had to move due to development of my airpark lots.
