Cabin heat from oil cooler.
svyolo
Junior Member
I have a roughed in cabin heat manifold for the back of my cooler. I have a RV-10 style mount so it was more complicated than one hanging off the baffles. It will slide in, L to R side and be held in place with sheet metal tabs. I have 2 2" heater outlets, and one 3" butterfly valve outlet valve to control oil temps. The 3 have about the same outlet area as the 4" inlet. I haven't tried it yet.
Making a simple manifold from a baffle hung cooler would be pretty simple. I will also be putting one on the Tailwind I bought if this works.
Here is the roughed in manifold. It is currently not a thing of beauty.
One trick with composites for very complex parts is to use smaller pieces/strips to build up parts. There is no way to mold something that complex in one piece. It started out as a pink foam mold, and I just built it up with pieces.
Another tip is to use "Twill" fabric. You can get both CF and fiberglass Twill. Twill CF is normally the outer layer for cosmetic purposes but it molds around complex pieces a lot better than straight weave. Fiberglass Twill is what I used for this piece.
This is a clever design.
I currently fly behind a rotax and we currently run lines from the water cooler through the firewall into a small secondary radiator with an attached fan for heating the cockpit. It’s extremely effective during the Utah winters. I’ve tried brainstorming a system for my Companion that did this with oil lines instead of a heat muff system. Any thoughts on this?
This is an experiment, but I have heard of others using it. Experience with old air cooled VW's has me wary of air to air exhaust heat exchangers.
We will see if it is successful.
I finally got my oil cooler heater shroud installed. I had to re-actuate my left cowl flap as it interfered with the shroud. Right at a standard day, flew to Idaho for about 2.5 hours. It was about 40 F at 9500 feet.
The heat seemed OK at first on climbout. Oil T got to about 205 F. Leveled off and it fell to about 185 F. Not quite adaquate for 40 F outside air temp.
My 13 row cooler/Vans RV10 mount has a 4" hose inlet. I have two 2" outlets going to my cabin heat valves, plus a 3 inch outlet with a butterfly valve. I had it half open today. I may put an actuator on it and see if I can get the oil temp in cruise up to 195 - 200. It seemed pretty good climbing up when the Oil T was 205.
Your oil temperature seems to currently be about where Lycoming recommend. (I run mine at about 185°f most of the time).
Is it the cabin air temperature being drawn off the oil cooler that is cooler than you'd like ?
Yeah I think they recommend 170-200 F for cruise. And I have seen mixed messaging on whether higher or lower in that band is better or worse.
  • Like
Reactions: Nev
