I used the automotive type corrugated tubing that is split down the side. The solid tubing seems like a nice, neat installation for wires that go from root to tip, but not so much for a harness that has wires branching off for things like pitot heat, landing lights, autopilot servos, etc. The split tubing makes that easy, just wrap some electrical tape around it on either side of where a wire branches off so it won't pull out, plus there are several sizes so where you have wires branching off you can go to a smaller size for those. And I second Jim's recommendation to run string or something to pull new wires later for expansion. I guess with a solid tube conduit you could put it in now and push a wire bundle through it later, can't do that with the split tubing that I used.
