I’m a newbie fabric guy. Do you rib stitch the horizontal round bar at the end of the elevator? Wondering since the fabric lays down in it. It’s not a rib but wondering if it should be stitched?
Ribs only, your fabric go over on to the other side 75% around the tube, your second side cover about 50% of the radius. With your tape on you will be good.
Thank you! Looks like tapes anywhere there is a metal structure underneath the fabric? Does it make sense to have a tape if there is a gap between the metal structure and the fabric?
You'll want to pick a covering syatem and follow their taping rules precisely. Covering is one area where the guidance is very specific and easy to follow.
I used Oratex's certified (on Pitts Special etc.) stitch-less system. Worked a treat, lovely finish too. No painting either required... was super for the interior also
