Here’s how I would do it. You are missing some fittings. I would use steel fittings, and seal the pipe threads with Loctite 565 or whatever sealant you prefer instead. No goo on the 37 degree flares which will be male on the fitting and female on your firesleeved hoses. If you are not going to use the mechanical tachometer, you can buy a nice cover for that port, which has provisions for safety wire.
