rodsmith
Well-known member
This is something I will be doing soon, but I am asking at the moment because a visitor to our airpark had a serious brake fluid leak on his Just Highlander. A couple of us have been trying to help him refill the cylinders. We have been trying to fill from the brake calipers up through the Matco parking brake without luck. With the parking brake off, we can't get fluid through the parking brake. It acts like there is a check valve which doesn't make sense. The brakes wouldn't release if that was the case. That is the procedure I was going to use to fill my brake calipers to remove bubbles that would be entrapped while filling from the top. Hope to hear from someone that has a Matco parking brake and successfully filled the brake system. The Highlander was built by a previous owner so he didn't do the initial fill.
