Hi all, for those like myself who are not using a skylight but going with the standard fabric covering, if you utilize a headliner overhead how are you doing so to still see the fuel sight gauge? I have only seen one photo and that is of a doghouse concept along the upper fuselage just below the top factory stringer.
Second question is I want to use an inertia reel with a Y or V harness and not simply a diagonal strap, so is it possible to do so with the factory welded tab or do I need weld a tab further inboard for the belt attachments? Thanks for any input.
