Help with estimating approximate weights of various factory Patrol parts
jj128s
Hi everyone. I need help with guessing the weights of Avipro factory parts (circa 2010?) to get an accurate as possible total weight for a trucking company that I hired to move these parts interstate for me. I don't look forward to being hit with an adjusted quote because I was way off with the weights. The quote is flat rate of 2000lbs or under. Any guesses will be better than mine from you folks who have a kit. I have searched the forum and came up with approximate weights of the wings out of the metal cradles. They are now in them, so I don't know how much more that adds to the 100lb weight. Fuselage I found was about 100lb too.
Below is the list of factory parts with my guess for some. I appreciate any input you have to offer. I know some of these are difficult to guess. Thanks for your help.
2 Fuselage one welded one tacked 210lb
2 Wings in cradles one with gas tank installed 210lb
2 Landing gear 14lb
1 Dynafocal Lycoming 0360 engine mount 14lb
2 Horizontal stabilizers 28lb
2 Elevators
1 Rudder 14lb
2 Flaps 14lb
2 Ailerons 14lb
2 fiberglass wing tips
2 Sets of rudder pedals with toe brakes
1 Torque tube
1 push pull tube
2 Control sticks
1 Fiberglass one piece nose bowl 7lb
4 Wing struts 28lb
4 Horizontal stabilizers flying wires
1 Gas tank
20 or so Stabilizer or vertical ribs
20 or so various sized 4130 tubing 70lb
The weight of a completed Patrol is around 1200 pounds so you shouldn't be anywhere near the 2000 pound flat rate qoute.
Thanks Rod,
Your right. I'm over thinking it. I won't be there till the day before the truck arrives for pick up and I need to submit my list with estimated weights before then. I know the weight is well under the 2k limit.
I'm going to talk to the agent today about max weight limit of one item. I'd like to bubble wrap all the loose parts and stuff them into the 2 fuselages. That would be the best way I think.
I'm going to bring a cheap luggage scale to keep track of total weight added to the fuselages. I can weigh all the parts that way except the wings and fuses.
