Horizontal induction to nose bowl...help!
DBeaulieu
Patrol Q/B Kit #79
Mounted my AFP FM-150 fuel servo Fuel servo to cowl.jpg to the engine to start trying to figure out how to get filtered and bypass air into the servo. There is not a lot of room for a filtered air box that I can imagine. Open to hear all thoughts on how to tackle this. Thanks so much!
Dave (from Maine)
You have two choices as I see it: 1-cut a hole in the nose bowl and install a forward facing scoop of some sort, or 2-do as I did and install a filter canister with a side intake routed up to the baffle inlet
Mark Dickens I've seen the thread with your solution...looks very good. Virgil may have something I can use, but still waiting to hear back. I think I would prefer intake thru the nose bowl but still pondering possibilities. Appreciate your response - your workmanship and insights I've seen on this forum are always educational to me.
Dave
Bcone1381 Thanks for the info Brooks. Bearhawk is sending out a version of an air/filter with alternate air kit to me. Should arrive soon and then hopefully it will be the solution for me. Will post outcome.
Dve
