Kit(s) availability for BH5
tcbetka
New member
I have been reviewing the BH website for specs and such on the BH5. Other than the quick-build and "advanced" quick-build kits, are there any parts available in the store? There's no entry for the BH5 in the "Parts" tab on the website, and I did see where Mark mentioned that there are sub-kits available for the 5...but I don't see any listed. Maybe Mark will see this, but I thought I would first peruse the plans-built area of the forums before calling him directly. My intention would be to build a fuselage/empennage from plans (basically, all the steel parts), but then buy a set of quick-build wings from the factory. But it might be nice to buy stuff like the tail wires and wing struts.
Thanks.
Tom
Give Mark a call. You definitely need to speak to him if you’re serious about this. He doesn’t work through marketing programs or third parties much. He will however, pick up the phone and answer emails, and I’ve found him to be absolutely reliable in every matter I’ve dealt with him on. I’m not sure how he does it, but he does. You may also be assured that any advice he gives you is in your best interest, not Mark’s. His gift to humanity I guess. He’s truly generous with his time and attention. I have no affiliation. I’m just a very satisfied customer.
I've talked to him a number of times in the past, although not for a couple of years. I was just thinking that, in a plans-built section of the BH forums, people might know about such things...so thought I'd ask tonight. I will certainly be calling him though at some point.
Thanks for your response.
Of course. Good idea and courteous of you to check if there is common knowledge circulating before you reach out for more details. Good luck, and welcome if you decide to do this.
Mark Goldberg has been especially busy as has been the factory. I suspect he's needing to balance the needs of the separate parts delivery with the needs of the qb kit orders, but he'll be able to tell you for sure.
I guess your plans have changed, as clearly you weren't talking to him about a scratch built Bearhawk M5 a couple of years ago.
This is a question only Mark can answer. You need to ask him directly.
They may have, indeed.
Thanks.
That makes sense Jared, thanks.
The whole idea here was to not have to bother Mark with basic questions that I thought might be easily answered here in the forum. So if I decide to take the next step, I'll just call him up. Since the website says ...Or you can purchase some sub-kits or components from us..., I thought it would be relatively easy to find this information here in the "plans-built" section of the forum since, you know, people in this section were building plans-built BH5 aircraft and are likely to be interested in buying parts they chose not to build.
Anyway, thanks for the help guys. I'll take it from here.
Thank you. At this point I'm really just trying to gather information and thus didn't want to bother Mark with a question(s) that might be easily answered by doing some research here in the forum...especially since I haven't made a final decision yet on how to proceed.
