Chewie
Well-known member
Any tips on reheating welded assemblies to fit a jig? I'm working on the flap hinge mounts. After welding off the jig, gaps are present between the bolt tubes/washers and the jig, as I would expect from shrinkage. But to reheat, is it best to normalize the entire mount at once or just the joints? Bright orange or just a dull red? And then do you put the torch down and quickly tighten all the screws while it's still pliable? I tried reheating a couple times but the gaps are still present. ~ 1/16" on all attach points.
Any advice much appreciated!
