The AN fittings for the fuel lines do not need any sealant as they are self sealing. Is this true even for the NPT fittings for the brake lines and the master cylinders? In my eagerness I fitted the NPT - AN adapters to the master cylinders without sealants and not sure if I should be disassembling these and reassemble with sealant.
Sealant for Brake Master Cylinder Fittings
I didn't use anything, apart from some 50 cent plumbers tape where the threaded fittings go into the callipers and master cylinders (being careful not to get any near the line).
You could also use the Loctite 565 liquid thread sealant, as used in the fuel system.
310 hours later, not a drop has leaked out.
