Aileron support frame
  • Aileron support frame
    Hey Guys, quick question. I am having trouble visualizing the bellcrank support on the aileron support frame on page 11. Specifically the 7/16"x.095 tubing. Is the "stub" facing up to provide clearance between the bellcrank and the support tube? The stub I am referring to is the .81" measurement from centerline.
    I also have a question regarding the pulley cross tube at the other end of the support frame on page 11. Is the 1" from centerline measurement on the top or bottom of the support frame? In other words, does the pulley sit flush with the support frame or raised above it 1" from centerline? Thanks
    Joe
    Good morning Joe,
    #1 Yes, stub up as you describe.
    #2 1" above centerline as you describe.
    Mark J
      Thanks Mark
      Joe
