elevator hinge gusset
  • elevator hinge gusset
    I built a set of tear drop shaped reinforce gussets that fit over the elevator hinge attach strap and bolts go threw them. I can not find in bear tracks where it says to make the change to this instead of the stiffener that fits between the two straps.Can some one point me the way,and do they weld on to the strap or just bolt over it. I can t tell. thanks all
    Mike, I think those may be something that came along for a little while in the first couple of kits, but were later removed.
      So what are the builders using to stiffen the strap that connects the elevator to the horizontal stabilizer.On drawing 21 hinge for elevator it show a stiffener 1/2 wide welded in. the tear drop was supposed to be a better fix , was it. what are they doing now.
        I'm speaking above my knowledge when it comes to interpreting plans. Bob is the person I'd recommend for that. I wonder if there has been a change since your set of plans was printed? Does your page 21 look like the attached picture, and are we talking about the same parts?
          We have the same drawings. Do you know how to contact Bob.I am pretty sure the change to the tear drop pieces was in a bear tracks as an update. they fit on top of the strap as a stiffener. I dont know if they weld on to the strap or just bolt on with the same bolt.it is too late to weld on the the brace that is shown as they are fabric covered and painted.
            Call him at 540-473-3661. It is not in the Beartracks that I know of, but there may have been one somewhere that I didn't know about. When you are able to get in touch with him, let us know what you find out please!
              will do thanks.Trying to get back into a project after 3 years broken leg and heart problems is not easy things are cloudy.feel free to call me 801 636 2362
