From what I can tell the wing skin overlap is the width of the spar web bottom. Seems that is what I came up with . So about 1.25"?
Wing skin overlap main spar
That's what I was basing my decision on. Couldn't find anything more clearly explained so I thought I'd ask as I usually do. I feel that there are no dumb questions...regardless if it seems straight forward to others or not. Thanks for the response. This forum is very helpful and reassuring!
John Snapp (n3uw) pointed out that the most economical way to purchase sheet material for skin is to buy it in 12 foot lengths. (6) 12 foot sheets of 020 and and (1) 12 foot sheet of 025)
some 032 material is also needed
I have not made my cuts yet, So, please double check everything. That said, I think that 6 foot sub piece is long enough to wrap with only a little waist.You do not have permission to view this gallery.
This gallery has 1 photos.Stan
Austin Tx
I did use 12' sheets cut in half for the patrol. I wrapped then to the aft edge of the spar. This keeps them consistent all along the wing. At the fuel tank area you do not want it to extend beyond the spar or it would make installing the fuel tank difficult. That is what set the length for me for the rest of the wing.John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
