I have mostly finished my first build table. Made it from 2 inch square steel tubing and 1 by 2 rectangular tubing. It is 4 foot by 9 foot and has 3/4 MDF top. I placed 3 inch long
#10 countersunk bolts to hold top down. I added small sheet metal shims between underside of MDF and steel cross tubes to level MDF where tubing wasn't.(level) Also installed 4
3/8 elevator bolts on bottom of legs for leveling. Done except for doing a bit more shimming and painting the top with white latex.
Now I m about ready to start on the mate to it. Not quite sure what shape to make the 2-nd half. One fellow I see- made his 2-nd tapered to narrow with tail boom and hinged
the connection between the tables. He could lift the table to follow the bend with the lower tubing. I had initially thought to simply make another table the same 4 by 9 size---
I am waiting for the Beta set of plans to appear--- My understanding is that the fuselage needs about 18 ( hence two 9 footers) and the wings need about 16 feet (4 place bearhawk).
I am wanting to be able to use just 2 table to do both wings and fuselage. If the wings are about 16 feet- since they are rectangular-- that would SEEM to mean that I need
at least 7 of the 9 feet of the 2-nd table to be the full 4 feet width. ( is that sound correct?) If that is the case it seems like I should just do another 4 by 9 similar to the first.
seems like the MDF wasn't as easy to work with maybe as ply would have been. Once I got the MDF cut- I figured that since this is central Florida and the summer humidity
is 120% for 3 or 4 months--- I fully varnished the MDF to prevent it absorbing water and warping. I expect plain 3/4 hardwood plywood would not need to be varnished-- maybe
a coat of white latex on both sides might be enough. (?) May use play on the 2-nd one.
Does anyone know if the BETA wings are longer than the standard 4-place enough that I need longer than 9 foot (18 feet total) ?
I think the tables are harder than the actual fuselage will be..... :-) I like the idea of using the wall mounted laser for leveling up everything. ( like the table tops to start with)
Any hints or post build wisdom on how you would do it if you had to do it again would be very much embraced !
Thanks- Tim
Thanks- Tim
