I have a question regarding rivet length, how much under or over the 1.5 x the diameter are you allowed? for example nose rib attachment angles require a MS20470-3 the -3 (3/16") looks like it is slightly to small by 0.01inch or 0.26mm and the-4 (1/4") will be 0.05inch or 1.33mm longer then required. Would I need the buy the longer MS20470-3-4 and cut the 0.05inch off the end of the rivet or would I by a MS20470-3-3 and just get away with the length being slightly short?
Regards Simon
Regards Simon
