Sometimes I get into minutia. But, this minutia in the above publication is a link to the Military specifications to aircraft riveting. I found kind of interesting.
AC 43.13 calls for a rivet's driven shop head thickness of .5D and head diameter of 1.5D. But the Mil Specs give us some tolerances that I had not seen before. In fact a 3/32 (.093 D) shop head thickness tolerance is .038 - .050 whereas I was looking for .5D (.046) as a minimum only. (why is there a Maximum Thickness Tolerance?) The Mils Spec head diameter minimum head diameter is .122" rather than (1.5D) .187".
When de-burring a rivet hole, I had never seen tolerances before, just "Not Too Much." Mil Spec says 10% material thickness. Rivet Edge Margins are also more specific and dependent upon the type of rivet being used...the mil spec 3/32 Universal Head rivet edge margin .156" (Thats equal to about 1.7D) whereas the AC43.13 standard 2D would be .188"
I look at having some tolerances as liberating. But its not AC 43.13. Give me some feed back.
Chelsea, MI
Scratch Building Patrol #303
