I'm just getting my head wrapped around putting the wing spar attach fittings on my fuselage and the process behind it. Alignment, incidence, clearances, etc. Out of all the info I have, it seems like most make the fittings, line them up using water levels, weld them, put the wings in place and match-drill the fittings to the wings using long contraptions. Adding to the mix is having the front and rear spar bolt holes offset from each other.
I was thinking...it seems the process would be easier to make and fit the fittings, finish drill the bolt sizes (5/16ths for the rear and 3/8ths for the front) through the fittings and spar attach points and bolt them together, using a very thin washer on the inside to compensate for future paint. I would then put the fuselage on the table, level it up and secure it. Then jig the wings in their proper position (incidence, distance from tailpost, etc) and tack the fittings to the fuselage? Once they were tacked in place with good tacks, you could also cut and fit the wing struts and put in all the pulley brackets for the flaps and ailerons at the proper angles.
Another option is to make a jig that mimics the wing spar attach points and use that as a guide, but would still need the long drill contraption to accurately drill the spar bolts. Any thoughts?
