I have my sacred and working master rib forms made (yeah) complete with steel drill bushings. About to cut out the cutting templates for cutting the nose rib blanks.
Remembering that there are 2 or 3 different lengths of them (depending on how many 1/8 layers are on the spar at the rib's position) So I have to know the lengths to
know how to size the cutting template. So i go the the spar page (5b) and look at the spar drawing. As I start at the root and go out to the tip (on the drawing) ----
when I get out to the tip area--- where the last 2 or 3 ribs would go---- the 1/8 reinforcements are not shown--- only the .032 sheet core. It shows the last 2 lightening
holes in the core .032 sheet and no other stuff attached there---- and then there seems to be an "end cross section" which looks like only the core. If there REALLY
is nothing else out there--- what do the last 2 ribs attach to ???? (this is a Bearhawk B )
I have Eric's CD coming ..... but prob wont be here till next week.
I looked for a pic of the spar on the web but most of the good pics showed it from the root end. -or it was the las version.....
Tim
Tim
