The rib plan (sheet 3 or 3B) depicts the center rib stiffeners installed with the vertical leg oriented toward the trailing edge of the wing. I know that the stiffeners can conflict with riveting the skins later if they are too close to the rivet location. If I install my stiffeners with the vertical leg toward the leading edge of the wing, then they align well with my flutes and provide ample room for riveting without clearance concerns.
Is the orientation of the vertical leg of the stiffener angle critical? Is there any reason I shouldn't orient the angle opposite of how it is depicted on the plans to provide better clearance for the skin rivets?
