Wing Build - virtually
  • Wing Build - virtually
    I've been hammered with work and life but got a little work done on the "planning" done.
    I studied the plans and Erb and Newtons works and my build buddy and I decided to build our form blocks and actual parts using a CNC (we have access to a shop with reasonable rates). So I took Drawing 4 and some cussing and I finally completed the main wing in 2D and 3D. I am still working the flight control surfaces, but the mechanisms are complete. Wing ISO.pngFlap mechanism.png
    Wow that's a nice drawing. I see you even got the cables in there. I have only the faintest idea when it comes to CAD. How did you get the original airfoil shape into the drawing?
    4 Place Bravo
    #1624
    Currently making form blocks
      btdobie,
      I took Drawing 4 (the Airfoil drawing) and had it scanned in at a blueprint shop as their equipment won't 'stretch' the drawing in any direction. Then I got a copy of Harry Riblett's book "GA Airfoils" as it explains how he does the airfoil layout (his XY plotting). Tracing the outside edge of the drawing and then using the XY layout gave me a set of points that I could draw a "spline" through which is a flexible line in CAD. I used this airfoil shape and added in both spars, ribs etc.
      It took a couple attempts to get the the scale right using the other drawings on the wing rib/spar layout...but I'm finally happy with the result. I'm trying to finalize the flight controls and then I'll CNC my form blocks for the ribs, pocket ribs, aileron/flap ribs. My build buddy owns a set of plans also so the little extra work with the drafting etc. will pay off when we build where we already worked out the bugs with fit. I decided to take the 2D drawings and make a 3D so I could ensure all the fits of all the parts...basically allowing me to build the wing several times, which helped me understand the build sequence.
      Good eye on spotting the cables...so I laid out everything so I could even CNC the holes in the ribs for the aileron cables, Flap torque tube etc. This way I can form a rib, rivet it to the spars and not have to go back in a fiddle with other work like punching holes for the aileron cable, pitot, or wiring for the wingtip lights etc. The plan is to CNC all the flat parts out with all the electrical, fuel and mechanical cutouts in them, then form them on the blocks and start banging the wing together. We are going to build a test bay of the first two ribs to check our tolerances...if that works its full throttle at that point. I think I've figured out a way to even cut the wing skins and all the rivet holes. We are undersizing the holes in case we have to move a hole. Most larger towns/cities have "maker spaces" that have CNC routers that are accurate enough...so we'll find out! I've done repair parts before like this so I'm confident I can make it work.
      The drawing you see here has .003" gap between all aluminum parts to allow for primer. I added another .004" for the steel to aluminum parts to allow for topcoat on the steel. All the edge distances have been checked and even rivet head clearances. You gotta have something to do while sitting in virtual meetings at work...lol
      We planned on starting back in the summer...but with the plannedemic its screwed up the schedule a tad.
      Andy
      • btdobie
        btdobie commented
        Wow you've really put a lot of thought into this. I would imagine having all the skin hole per drilled would be a huge time saver.
      Good morning, Wyo,
      What CAD package are you using?
      All my best,
      Rob
        Rob,
        AutoCad, but Solidworks you can get free with an EAA membership. either work well depending on how exotic you want to get.
        Andy
          Curious if you are thinking 1 at a time or going for broke and stacking as much as you can between a backing plate and some top plate?
          Watching 10+ parts come out at once is always nice.
            Bentmettle,
            From the CNC minions I've spoken to they .025 and .032 material that the wing ribs are made of get squirrely in a mill. I guess it likes to climb the bit. The machinist thought that 4 or 5 layers might be max...mainly due to if something goes "horribly wrong" you are only screwing up 5 parts at a time!
            It really depends on the tooling and the machinst...kinda like wood working...a craftsman table saw will rip plywood but not at the same tolerance a luguna. Just depends on your tolerance (and budget).
            My current plan is to layout the ribs in a 4'x8' sheet as most CNC routers have that bed size. The other option is to not cut the parts completely out, but to leave small tabs in a few places. This does a few things, one being I make sure I don't get a substitute part (I will part mark the raw material with a sharpie etc) and it will minimize tearout on the part and finally easier to screw down the sheet to the CNC.
            Andy
              I have a CNC mill in my garage. When it came to making the wing ribs, I used the mill to cut wood templates for the various ribs. I made duplicates of the blanks out of 1/4 plywood to use as backing plated to protect the ribs from the router and hold the ribs flat as I cut them. I then sheared blanks for all the ribs. I found that I could stack 4 rib sheets between the template and backing plate. I had 2 3/16 inch dowel pins to locate the templates, rib blanks and the backing plate. I used a hand held router to cut the ribs. The rib template was fastened to a work bench. It took under 3 minutes to cut 4 nose ribs. I used 1 3/8 diameter carbide router tool bit that had a bearing guide at the bottom. One bit cut all the ribs for the wings.
              Several of the rib types are too large for my old CNC mill to machine without shifting the parts several times. I think that the hand router was the fastest way to cut the ribs. The edges took very little time to finish with a wheel and hand polishing equipment. I used 3.4 MDF board for the templates. Having 2 dowel pin holes to locate the ribs in the cutting and forming templates and other tooling really speeds the operation and precision.
                Good info S Lathrop.
                I'll try and post a pic of the rib layout, it looks like I'm are doing a similar approach to yours just using 4x8 sheets stacked several deep (4-5 layers). Those layers will get screwed to the top of the CNC router table...so every pass results in 4-5 ribs at a "plunge". To keep the ribs from jumping and getting damaged by the passing router bit I left small 1/8" tabs in a couple locations on each part...we ran a test part on a single part and it worked well, the tab is easily nipped of and smoothed off with a flat file.
                The CNC router allows the full size end rib to be cut without moving the set up also.
                Andy
                  you should do a you-tube series on how you did this....lots of us would watch....not much out there about this sort of thing...
                  great work
                  maybe youve already done this...just mentioning it..
                  please make sure your wing shape matches the original...print off your shape and see if it matches the original...or check reference points...ect...
                  I would not trust the scanning...without physically checking it...
                    I cut all the aluminum panels for my Patrol on a CNC router. A couple tricks. Use a down spiral bit and cut everything with tabs. Your parts will stay nicely in place even when doing them one at a time.
