Wing Strut Attach Straps
  • Wing Strut Attach Straps
    I just finished riveting my rear spars and getting ready to re-assemble and rivet the main spars.
    I hate to ask questions that highlight my lack of knowledge...but here goes: regarding the wing strut attach strap fittings that bolt onto the spar, the plans call for 0.190 thick 4130 N steel. Does the N stand for 'normalized' as opposed to 'annealed'? Does Wicks and/or Aircraft Spruce provide 4130 N steel?
    As a follow-up question to the type and source of the appropriate steel to make these parts...would it make more sense to just buy these ready-made parts form Mark for ~$120 ?
    Also, how hard is it to accurately match drill 1/4-inch holes through the steel straps into the thick stack of aluminum at the splice.
    Karl
    Northern Idaho
    Yes 'N" is normalized. Do not use "A". If in doubt, ask for a cert. A mill mark is the best identification but you might not get one on such a small piece of plate. The problem with raw stock is that the part is longer then 12". Raw stock is generally sold by the foot. A 1'x2' plate of .190 is pretty heavy and costly to ship. Plus you have to be able to cut, shape and accurately drill the .190. And you end up with a lot of matl you'll have to sell to another builder. The prefab parts are good value. I went at the holes a little at a time, enlarging the steel off the assembly and using a drill press and the strap as a drill bushing to drill the AL. Use LOTS of clamps and T or L pins. Have a plan and work the plan. Try not to drag big steel chips through an AL hole bore. Reaming can't hurt. Learn about MS bolt diameter tolerances. This is a part of the airplane that demands your full attention.
    Gerry
    Patrol #30
    • kilohotel
      kilohotel commented
      Thank Gerald! ... but....what are 'T' and 'L' pins ?
    N is for normalized which is different than annealed. Most of what Wicks and ACS sells is normalized unless noted differently.
      If I were to do these again I'd buy prefab, but I would still do the drilling and reaming myself.
        Thanks! I ordered the parts today!
        Karl
        Northern Idaho
          Google Carr Lane for the full story on L and T alignment pins.
          Gerry
          Patrol #30
          • kilohotel
            kilohotel commented
            That worked! Thanks!
