Finished up the first set of pulley cable guards. These are for the pulley mounted on the aileron steel stanchion. Thoughts?
Pulley cable guards
Pulley cable guards
This gallery has 5 photos.Dave Bottita The Desert Bearhawk
Project Plans #1299
N1208 reserved www.facebook.com/desertbearhawk/Tags: None
Dave. They look very nice. Looks like a nice design. my one comment would be about the screws. Can they be locked? could you use a clevis pin and cotter pin or a bolt and locking nut in place of the two screws and standoff? I would want to make sure there is no way for the screws to come out. I like your design a lot though.John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
Loctite 690 will do the trick!Dave Bottita The Desert Bearhawk
Project Plans #1299
Looking good, just make sure to locktite the screws and put some torque seal on them so you can see if they rotate any. Might want to consider hogging out some of the center of the U bracket to lighten them up a bit, every little bit helps keep it light. You would then have 4 "fingers" holding it in place rather than 2 sides...if that makes sense.Joe
Very flash!! Cosmetically and functionally very, very nice.
From an engineering perspective, I trust you already know you are over-engineering a very simple part - which I perfectly understandable - because I guess you must be building for the sheer love of it!
If you can put that kind of engineering ability to use on improving the function of some part in a big way, e.g. a change to fowler flaps, that would really help the plane when you're done. You won't be able to enjoy the extra engineering on those hidden parts except when you annual the aircraft.
Those pulleys and cables seem to have a very low wear rate, I think they will last at least 1000hrs.
For the love of building/creating. I guess I'm OCD that way.... Thanks for the kind words guys!Dave Bottita The Desert Bearhawk
Project Plans #1299
Beautiful work Dave, aesthetically and functionally perfect.......
I'm using Stewards Ekoprime. It's water based.Dave Bottita The Desert Bearhawk
Project Plans #1299
