I am boning up on fuel tank construction and have a question. My plans are showing using .025 aluminum for the hat shaped stiffeners in the fuel tank bay. I've seen where a couple other builders referenced .050. Could someone clarify? I probably missed it somewhere. Plans #496
Fuel tank bay skin stiffeners in the 4 place
For my A-model 4-place, the top skin stiffeners I received with the QB kit are .050”. This matches the callout on the bottom left corner of sheet 2 of my plans.
Plans 612.
Mystery solved! I recently had Bob send a set of 'shop' drawings as mine were getting rather tattered and worn. The set he sent me shows a revision of 10/09/02 for sheet #2 and showing .050 for the stiffeners. I ordered my plans in December of 01. I reread the wing test results in the October 2002 newsletter which talked about it also. So, there I go.Last edited by woodtic; 03-20-2024, 06:05 PM.
