I'm curious how many other quickbuilders have done this. As you know, if you are doing a full skylight, removing the 2 middle formers aft of the windshield is necessary to allow the plexi to bridge evenly across the cabin. This also makes the addition of a terminal cross bar at the aft end of the plexi skylight necessary, where the plexi will be anchored and my fuselage fabric will wrap.
Battson did this and had good results, but he reminded me that it makes adjustment of the stringer standoffs down the spine of the aircraft necessary to have a nice straight line without any "humpback" look. Think about how nice the backbone of a Super Cub looks. As you can see in the photos below, I'll have to drop the standoffs to maintain the "green line" which is my proposed top side of the stringer. Also, the mid-run fairlead for the elevator trim cables (not used due to electric trim) will have to be removed.
Current plan is to measure, cut them, internally sleeve the 1/4 x .035 standoff tubing with some 3/16 4130 tubing, and plug weld them in. I've seen others tap and use all-thread, but the sleeve and plug weld seems quicker, and I won't have to risk welding on the actual T-10 or whatever the fuselages tubes are. I have custom brackets already built to terminate the stringers at the crossbar.
Thoughts? Anyone have photos of theirs if they did similar?
