I realize the Gerdes master cylinders from AviPro are recommended/preferred, but I'm having trouble finding the specs on them. Can anyone provide the specifications for the pin-to-pin length and required stroke? It seems like the dependent factor is the design of the BH brake pedal, this would be well documented but it's not called out on the plans.
I could measure the brake pedal travel I suppose but this seems like something users who've installed and tested their brakes would readily know.
Also, I assume the remote reservoir is required because of clearance limitations? Or is it just because those gerdes cylinders don't have an integrated reservoir?
Thanks.
Thanks.
