fabric covering
  • fabric covering
    Hi I am new to this site I am building a QB 4 place in Tasmania, Australia. I am trying to put together a list of parts to keep my project moving. has anyone done such a list, what is needed to complete a kit. this would save a lot of time and freight costs. I am up to adding counter balance weight in elevators and I need to work out of weight of finished coverings does anyone have a list of fabric required to cover the complete project including tapes, tape widths, threads and size of threads if thread is even required. I am thinking of using Stewart's Covering system.
    Thankyou
    Dwayne Barwick
    Stewart's has supplied fabric to several BH builders so they already know what you need. Send them an email and they will get back to you with an itemized quote. I recently purchased my fabric from them and so far quantities seem correct.
      Dwayne;
      I can't help you with any list of the the four place but I think you are on the right track and to encourage you to develop an exhaustive hardware list. I am building a Patrol, and I made an attempt to compile an exhaustive hardware list for it. Doing so really helped me get to know a lot of details in the plans and the assembly process. I also have found that building accordance to the Plans, with no changes will make things a lot easier when ordering your stuff.
      My method was toI make up a spread sheet for each page in the plans, and developed a hardware list for each page. For example, page one has nut plates, rivets, machine screws, etc. After each pages hardware was developed, I scoured all the pages for each tip of items that were alike. I then compiled secondary sheets with a variety of hardware categories, like Rivets, Bolts, Nuts, Cable Hardware, etc. On these secondary sheets...like the Bolts Sheet, I have each specific "Bolt" that is called out in the plans, like an AN3-3A, and a total number that I calculated that I needed. This gives me a total of all the bolts I think I needed. I did the same for washer, nuts, nut plates, machine screws, etc.
      This preparation helped a lot. When I am ready to start a new step, I should have everything, and can just go and get the hardware, and parts. It took months to compile this list, but I am glad I did it....I also must confess that I enjoyed the process, which might reveal a compulsive disorder of some magnitude I suppose.
      In the end, I failed, because my exhaustive list is missing stuff. But I keep updating it. As I build, and I find things that I need, I make a shopping list, and try to put a supplemental hardware order in about once a month.
      The categories that I used (And it might help you develop an accurate list when going thru each page of your plans) is
      -AN hardware (for rigid AL tubing),
      -Bolts
      -Bushing Stock
      -Cable Hardware
      -Clevis Pins
      -Machine Screws
      -Nuts
      -Nut Plates
      -Rivets
      -Tools
      -Washers
      -Other General Hardware items.
        Thankyou for the reply's I will email Stewart's and see how I go. When I look at my plan they call for a bolt or nut plate, but no details for example my plans just call AN 4 bolt no length or if it is drill or not. It's not the end of the world.
        Thanks again
        Dwayne
          Bob never specified bolt length in the Patrol Plans either, so I calculated each bolt length using the material thicknesses that are given in the plans and used the guidelines in AC43-13 to determine if the bolt required a Castellated nut or a nylon lock nut. I also have drilled a few of my own bolts. I made a drilling jig out of a spare nylon lock nut that has resulted in a lot of satisfaction when I don't have a drilled bolt on hand. Regarding Nut Plates, I planned for number 6 machine screws almost everywhere that the plans merely specifies "Nutplate". I then ordered a rather small supply of #8 nut plates in case I need some.
          But you are right....calculating bolt lengths is laborious, but less so than I think than taking measurements off the kit. (I have time to kill in hotels when I am on the road, so it worked out pretty good.)
          A website I used extensively that helped determine the specifications of hardware is http://www.gen-aircraft-hardware.com The menu on the left side of the home page has an extensive list of hardware. Click on "Tech Info" and a .pdf file comes up with all the specifications and mechanical drawings of each hardware. For example, if you need an AN3 bolt with a grip length of .125" click on bolt, then Tech Info.
        Brooks, would you be willing to share your Patrol hardware list with the rest of us? I tried to keep a log of all the stuff I used as I went along, but quickly realized I was failing to go back and update when I changed something out later on. Now I find myself often "painted into a corner" when I need a bit of hardware that I don't have. Spruce has gotten a bunch of little orders that way. I keep a running "wish list" of things I know I'm going to need "sometime" and order them along with my last-minute hardware needs...
        Jim Parker
          Jim;
          I am willing to do what ever I can do to help the community. But of course I am not done, and so the list grows, and I change my mine on how I will accomplish things. Like cables....when I developed my list, I planned on ordering cable from Spruce with Swaged terminal ends, and no turnbuckles on the rudder cables. I ended up swaging my own Nicopress eye splices and so I ordered more "stuff." I also find that I am not following through with updates like I should.
        • JimParker256
          JimParker256 commented
          You sound like me... I started off so well, always remembering to document everything used. But I missed one thing here, and two things there, until I realized that my list was useless, even to me... This is the one area where I've driven myself crazy. Seems like I get 95% of the way through something, only to have to set it aside for a week or so while I wait for the right hardware to arrive.
