I am in the process of roughing in my aileron and balance cables. I recall reading (cannot find the post now) that tensions are typically set at approx 30 lbs but that less on the aileron cables (25 -26lbs) makes for lighter stick pressures in roll. However, when I set my aileron cables to 26 lbs tension, I am getting 39-40 lbs at the balance cable. Is this typical?
Also, no matter what adjustments I make, I am seeing 25 degrees up and 20 degrees down aileron deflection. I've tried adjust the push rods but that doesn't seem to make any difference. Any ideas?
Thanks.
Thanks.
