Managed to get my hands on some sheets of 1/4" 2-ply fiberglass nomex core honeycomb panels, 3lb core. I plan to use this for the floor boards and possibly the aft bulkhead. Compared to .032" 2024 I calculated the weight for the sandwich panels at 1/2lb heavier over a 4x8 sheet, so fairly close in weight. I also plan to leave them unfinished, with thin carpet over them, and I'm thinking about neoprene edge trim to close out the open core along the periphery (via McMaster). Between the frames the panels rest on I'm considering neoprene again, but I'm concerned about vibration and wearing through the fiberglass, I just don't know yet.
My reasons for doing this are:
-Sound absorption, the sandwich panel will provide greater noise protection than the aluminum sheet without having to coat it with something heavy.
and
-Stiffness, I've seen some excellent examples of beading the AL floor boards. While this looks very nice it's something I'd rather not have to do. For actual flooring you usually see 9lb core, but the 3lb seems quite stiff enough for this application. No high-heel punch through to worry about in my BH
I'm debating whether I want to pot thru-inserts or just blow clearance holes through the panel to attach them. I think I'll need some blind inserts to attach things so if I'm doing that I might as well pot the others too. Anyone have experience using these in GA, or for my application specifically? I'd love to hear your thoughts about this, I only have experience in commercial interior monuments but these seem like a fine alternative.
and
