Builders,
What did you guys do to attache the lexan in the front near the windshield? Did you just run a screw through the a fairing strip, then the lexan, the u channel, the windshield, then just put a nut on the back side? I suppose that would work.
I guess you could make a u-channel facing back to capture the lexan. Weld it on?
Curious as to what others have done since I'm starting on my skylight.
