My latest offering: https://www.youtube.com/watch?v=6-lRbVEu89k
Aux Tank Connection to Facet Fuel Pump
Hi, my facet pump came with the fittings( 1/8 NPT THREAD WITH 5/16 hose connector ) the challenge was how to connect them to the one way valvle, I took a two way joint and cut the threads clean, drilled the hole and tap it to fit the 1/8 NPT tread. Now I can connect the fillter and the 3/8 line from the tank through the one way valve very easily.
Facet makes pumps both with and without the internal check-valve. The check-valve prevents fuel from flowing "backwards" through the pump body when the pump is not running. The "flow-through" pumps are self-explanatory by contrast.
If you use the "check-valve" type pump, I would think you would be OK without a secondary external check-valve, right?Last edited by JimParker256; 01-29-2021, 07:17 PM. Reason: Edited to remove my "boost pump" diagram and explanation, which was WAY off topic, as AlaskaBearhawk pointed out below! Not sure how I went there in my head...Jim Parker
