I am still stuck on the wrong side of the world, hopefully for only another week. There is at least one 4 place with 100 gallons of fuel. I haven't closed the wings yet, but they are ready. I didn't do aux tanks because they added 30 lbs, and if I needed more fuel, I didn't think 18 gallons was enough. What does it take to add 50 gallons of fuel? If you put the other 25 gallons per side outboard of the struts, they would have little structural effect on the airplane. The main tanks get away with hat sections stiffening the wing skins to maintain shape. Is there any reason you couldn't duplicate that outboard of the struts?
I didn't think 30lbs were enough to justify 18 gallons of gas. I might accept 60 pounds to justify an extra 50. I know the moments would reduce the roll rate. I am not building a Pitts. I am building a back country tool. Putting it all the way out by the tips might make the most sense for loading, but worse for handling.
