I am finding it hard to pull the last notch of flap during backcountry ops. Especially when I might be turning in a tight space, or focussing outside, when I need more flap. You really have to get your body in behind it. I have actually pulled a muscle in my arm on two occasions now! I use a high seating position to see clearly over the nose for STOL ops which makes the problem worse, it's really only the last notch which gives grief. I am observing the Vf speeds, and in most cases going slower than necessary before adding flap.
Has anyone though of ways to improve this?
One idea I had was lengthening the bar, to reduce the necessary force and make the bar handier for the last notch. I have long arms so the reach isn't a problem, and you can simply grab the bar lower down for the first two notches.
I also thought of using a larger grip as part of such an extension. That little 3/4" tube is pretty hard to grasp firmly. In summer with hot hands, my hand has slipped off the top a couple of times.
I also considered installing a large spring to reduce the force required, although a spring would provide less force the further up you move the bar - when you really need more force, not less.
Has anyone spoken to Bob about this kind of mod? Any other ideas?
(please don't recommend that EZ-flap product....
P.S. This is also an issue because my financee can't fly the Bearhawk herself, she's not weak but also not strong enough to work the flap handle. Maule flaps take almost no force at all, why is there a difference??
