Thanks to everyone on here, I post very little and use a lot. I have tried to stick to the script to keep build time lower, but I came across a thought for my first major(and hopefully only) deviation. I am using oratex and that is applied a little different with a top piece being last in a "V" shape from behind the pilot to in front of the vertical. My kids are young and will be with us and I enjoy a skylight, why wouldn't they, it always gives a more roomy feel.
Attached are 4 pics hopefully in order. The first one just blues out the usual skylight with the added area over the rear pax. The next pic is the outline with more of the frame showing with the third highlighting the under structure(some reinforcements need to be added back there) that all the skylight would be attached to. The last shows where the sky light is held down either by screws or rivets through strips or channel. The last pic color scheme is red for strips, yellow for channel, and the teal could be made to be either.
Does this impact safety in anyway?
Yes its heavier, yes it cost more, yes it will be hotter in the summer(but nicer on skis in the winter). I am aware of the cons, but don't want to miss anything that could relate to safety. If you can think of anything, let me know.
Thanks
Thanks
