I've been working for a while on a project that will hopefully consolidate building information, and give builders a topic-based source that can be revised and expanded as time goes on. One key component of this project is a task list that will help keep the building steps in order. Imagine a chart shaped like a tree. The trunk of the tree (the pointy end) says "test fly your airplane." The other end has a list of tasks that can be performed without any prerequisite steps. Those two ends are connected by all of the tasks that must be completed in a particular order.
Where I'd like to have help is with fleshing out the tree. The preliminary "rough draft" is here. It's still a work in progress, so keep that in mind. If you'd like to help, take a look at the list and reply here (or send me an email) with any tasks that you know of that aren't on the list. Focus on tasks that you have needed help with, or needed to do research about. Eventually, each task is going to be a link to a category of solutions to completing the task. Don't worry about describing the tasks, or about getting them in order (unless you want to)- I can do all of that, just list them by name. For example:
Bleed brakes
Mount tires
Create Instrument Panel
etc.
Thanks in advance!
Bleed brakes
Mount tires
etc.
Thanks in advance!
