Not the usual OA vs. TIG thread
  • Not the usual OA vs. TIG thread
    At our last EAA Chapter meeting, someone asked me how I was planning to weld up my Bearhawk. I told them that I had an OA rig, and then I got the, "Oh my god, you won't believe how expensive it is to buy gas now" speech. To be honest, I haven't emptied my tanks yet since the original acquisition, so I have no idea how much gas is now.
    Although the costs may be localized, anyone have an idea of the cost of gas versus buying a nice TIG along with its consumables? I imagine that there are those in tune with this environment more so than myself.
    I'm just wondering if his reply was anecdotal, or if there is actually a significant cost differential. The folks on Supercub.org seem to think it's a wash.
    I can't answer your question directly. The TIG I am using is a loaner but I have refilled the argon bottle at least 6 times at ~$60 each and about ~$20 worth of tungsten. I bought my project with the frame fully welded and have been just adding all the fittings which is quite a bit of welding. I would budget at least $600 for argon for a TIG rig. I also have a OA rig that I've have for years. When I started I had 150psi of acetylene and 500psi of oxygen. I've refilled the O at a cost of ~$40...I think. I've got virtually no A left. If I was good with a OA rig I'd give the TIG back. Off the cuff I'd bet, acquisition cost aside, either system costs about the same to operate.
      wow, thats seems really high, what kind of flow rate are you using? gas lens? postflow time?
      • whee
        whee commented
        The guy that loaned me the TIG, a professional welder, said to set it at 30CFH. I had a friend come help me a few times, another professional welder, and he said 30CFH was probably enough since I was in a enclosed space. I post flow till it is no longer glowing red. From the indicators I know this is just enough gas; I certainly wouldn't run any less with the setup I'm using.
      In the realm of airplane expenses, then I suppose they could be called a wash. 5 years ago I spent about $900 on the OA setup, which included a kit from Tinman with his expensive lens and buying my own bottles. Filling both bottles would probably be on the order of $100, but I haven't needed to in quite a while. Apples to apples, I think the initial setup for the OA is still going to be much cheaper. I can't really speak to consumables, but I would suspect that they are going to be similar. The TIG would have better cross-project utility and resale value, which may help offset the cost of initial purchase if you consider those factors.
        Hi Chris, I purchased my oa rig around 7 years ago for around $500. It is a smith HVAC Porta torch kit with the little bottles, lifetime warranty torch, regulators, hose, and a carrier. I used it on several projects for around a year before I bought big bottles for it (k size ox and a 140 size acetilyne...the standard cutting setup). The o2 lasts around twice as long as the acetilyne. In western ne, a k size o2 bottle is around $ 30 or so and the acetilyne is around $85 or so. I get mine from linweld and they simply exchange bottles after you buy them and take care of the pressure testing. I have checked into argon in the past and I remember it being priced competitively to acetilyne for a bottle that will last as long as the acetilyne. Smith welding tips run around 30 bucks each and I have yet to wear one out. I have no experience with TIG however when I looked into it, it seemed like it was a good way to get nickeled and died to death...just my opinion. My original big bottles have lasted 5 or 6 years which included many cutting, heating, and fab projects. I also learned to weld with the big bottles and destroying quite a bit of aluminum learning to weld aluminum.
        Joe
          I have a super welding supplier locally. He may not always be the cheapest, but he will take care of his customers. This year I paid $20 for my oxygen and $75 for an acetylene refill.
          Stephen B. Murphey
          Bearhawk LSA
          Building #L-089
          • Chris In Milwaukee
            Chris In Milwaukee commented
            I leased my tanks from a dealer in Madison, WI. Now that I've moved two hours north of there, it's a long trip to take my bottles back to be refilled. My local supplier won't refill them because they aren't their bottles. I guess the easiest thing to do is go down and ask them how much to use theirs, right? :-).
            That price is certainly not scary at all.
          • sbmurphey
            sbmurphey commented
            At work we had a change in our state contract this year. From memory, the monthly lease rates on our new bottles was just under $2.00 each. This covers hydro testing and the valve when necessary. There was also a small discount on gas price worked into the contact. I have always preferred to own my personal bottles. I typical do not use that much gas over the course of a year.
          If you have the gas system why add to the cost by purchasing another system unless you feel the system will be used for a lot of other projects. If you tig weld you need to spend additional time in making quality fit up of your joints. Gas has a wider heat affected zone and therefore fit up is not as critical.
            Definitely a plus for OA. Fills gaps without tight fits (we actually learned how to do it in Earl's class). Planning to keep using it, definitely.
          I have the Tinman setup, and a pair of big bottles, and thus far am perfectly content with them. I took the SportAir gas welding workshop a few years ago with the Meco (Earl Luce instructing), and I really liked the results with the limited projects we did. Two years ago I took the gas welding workshop again to brush up on my skills since I hadn't welded with it since, but I chose to use the torches that EAA had in the class (comparable to the Smith torch in form). I found I wasn't doing as well.
          Since I'm planning to weld up tanks, too, I thought I'd ask about a TIG rig. I have Kent's video for welding aluminum with the Meco, and it's a great resource. But I know that a lot of folks prefer TIG for welding aluminum, stainless, and other exotics. And some folks swear by them for steel. All in what you started with, I reckon.
          I'll continue with the Meco, and if I destroy a lot of 5052 while attempting to weld tanks, then I'll send them off to be made :-)
          Thanks for your insights!
          • bestbearhawk1231
            bestbearhawk1231 commented
            There is always the option of riveting the tanks with sealant RV style. Personally I am not able to justify the price of even a "cheap" Chinese one like an AHP alpha tig + bottle+ all the add on junk that goes with it at this point in my life. I can screw up a lot of aluminum and stainless steel learning how to OA weld with the proper flux for the price of a TIG machine. All things aside if you do not consider the entrance fee of either process, I don't think there would be all that much difference in operating cost. One other nice thing about OA is that you don't get sunburned if you don't have a full face shield and long sleeves.
            I certainly agree about the sunburn!
